- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
I thought that this connector was under the front seats? So you replaced the one on the passenger's side?
H mm, I have had a code 36 flashing since I rebuilt my 99. I have a 2000 model airbag module, so I assumed that it is expecting side airbags which I don't have.
Is it possible that the 99 module is no different, and the connector under each front seat tricks the module into accepting the input? I have used resistors of 2.2 ohms trying to do that manually. I didn't know that there was a resistor inside of those seat connectors. I'll go flip my 99 seats to see those more closely. Regards,
The side air bags are in the front seats.
Does anyone know what a flashing 3 7 code means?
Thanks.....
Welcome to this forum, and thanks for making your first post informative!
Yes. Code 37 is "Driver-Side air bag resistance is high", you do not have side airbag (only the one in front on the steering column is what you got on the driver side) and thus the yellow plug is a resistor that substitues for that. If for some reason it is not making good contact, you well get that error. unplugging and cleaning the connector helps stopping that code. I have been doing a lot of readings on the subject.
