diode and resistor wiring.
HI There.. Great post, and install by the way ...I am thouroughly confused and stuck; have been for 2 weeks now. Hope you can take the additional time to help a fellow out.
1) Can you possibly detail the wiring of your unlock trigger assembly (the one you made)
a. The diode direction is not clear
b. I can not understand why you need resistors
c. Why 8 diodes instead of 4?
2) Where excactly and what wires did you tap?
a. I have the car gutted, so I can access ANY wire ANYWHERE
b. The wiring schematics online seem to contradict the done light. How did you trigger it?
c. I can not find the door triggers in the drivers sill. They run from the sheath in the drivers kick panel, and I can access all of them.
3) Did you diode protect any other wires.
4) is it neccesary to place a relay on the rear glass pop, and where is that wire. What polarity is it?
Thanks so much for the help
Tommy
