Yes the tech put in a different bushing with less degree but it made more negative camber (-4.17). The previous owner had radius arm bushing problems with elongated holes in the chassis bracket but I replaced the stock setup with the real beefy James Duff radius arms and it was since that installation that I drove 80,000 correctly aligned, trouble free miles. I'm positive now, thanks to your input, that once I re-install the stock brackets, I will get the alignment correct. The tech referred me to 2 off road/custom suspension shops that specialize in custom lift/lowering, but all they could tell me is that the TTB was one of the most difficult front ends to lift/lower and they didn't like working on Ford products because of so many variances in the vehicle suspensions/mid year changes. With your hands-on experience, you actually gave me more info/insight into this then they did. There must have been some manufacturing variances in these vehicle suspensions from year to year; 1) in reading the description of the 2" drop pivot brackets, it states "Ideal for Fords (Ranger 1983-97/Explorer 1991-94 4wd) that have been lifted 1.5"-2.5" without changing stock axle pivot brackets and "have problems with alignment", so I'm guessing some Ex's will need them only if you have alignment problems "after the lift". My fault for not reading/understanding it correctly the first time and anticipating a problem I did not have! 2) After I installed the James Duff radius arms, several local offroaders told me that they are only for lifted vehicles, and my caster would be way off, yet it brought both the caster/camber within spec better than the stock arms.
Again, Much thanks for your help,
PCTechman
