Allaa's 2008 Explorer XLT 4WD V6 | Page 3 | Ford Explorer Forums
I have to say I'm very impressed with what you have accomplished with your Ex. What did you do in order to dyno it though? Did you remove the front drive shaft?
Thanks Sean
Regarding disabling auto 4x4 you just need to remove fuse #33 ABS pump 30A and the Explorer become 4x2 (applicable in 4WD models)
I'm curious, how does pulling the ABS pump fuse disable 4wd? And other than the ABS light coming on (I'm assuming here), does it cause any other issues/or codes?
The auto 4wd monitors wheel spin through the ABS sensors.
in 4x4 Auto mode, the 4x4 is actuated by AdvancedTrac® with RSC system when needed
by disabling the ABS pump you are disabling AdvancedTrac® with RSC system completely and you will get a theatrical alarm with a massage to service RSC now, and the truck will become 4x2 in the 4x4 Auto, and 4x4 in 4x4 high
note: if you pulled the ABS pump fuse while the truck is running, then you can engage 4x4 low
but if you pulled the fuse while the truck is off then you will not be able to engage 4x4 low
I am going to pull that fuse today and hope it solves my front ABS sensor issue until I can get it replaced this week. My Ex keeps going into 4wd on dry, straight roads. Frustrating.
did it solve your problem?
Today I ordered ScanGauge II for $144.21 from Amazon.com after hearing lots of good usage of it from lots of members over this forum :D
Great pic's mate, hope you have a good time with the scan gauge. I've only heard good thing's about it too.
Thanks mate, I hope so
Last night when i was going back home the alternator quits on me, I think half of the coils burned up. I had to stop the A/C and keep the revving around 2000-2200 RPM so the alternator would generate enough power for engine and lights.
today morning I went to ford dealer to buy new one, and for my surprise he have only Motorcraft re-manufactured and no new OEM
It costs me $162USD and I install it right a way in the parking-lot and everything is back to normal.
You will like the scanguage II :thumbsup: Did you purchase the blendmount kit as well (for mounting it to the rear view mirror) or do you plan on mounting it elsewhere?
no I didn't
I'll use 3M double side tape and stick it to the dashboard :D
Last weak I started my vacation, so me and the family went back to our home town Makkah in the western region on Ursula.
It was 813 mile driving in 12 hour trip, were I got 18.2 MPG with speed of 75 MPH
Today I received
Sterling Equipment & Mfg. Co. Gator Model Winch Mount Brush Guard with optional add on light bar kit and 1” rod tow loops - Part# 83XGWP-G – W/L - W/1" Rod Tow Loops Under Cradle
and the
Mile Marker 12,000 lb Hydraulic Winch Part# 75-52000C
I'll post the pictures as soon as I install them on
Here are some photos I snap for the Winch Mount Brush Guard while I was changing the oil
hopefully by the end of this week or the week after I'll finish installing the winch with the light bar and lights
for an unknown reason the harness off the transfer case got tangled with the drive shaft, now my Ursula is a setting duck with out 4x4 :(
I tried to get the harness form the local ford dealer but it turns out that they don't provide. :banghead: :mad:
so I ordered them from GaryYeomansFord.com through fordparts.com
6L2Z-7A786-BA
8L2Z-7A786-AA
hopefully they come soon
Up to date I'm waiting for the harness, 6L2Z-7A786-BA is on back order and Ursula is still without 4x4
