An extremely good deal or a Hoax ? Cheap Performance chips | Ford Explorer Forums
Rip off. What things like that usually do is add a resistor in line with the MAF sensor to send the computer false readings about airflow so the computer dumps more fuel into the motor. More fuel is not always a good thing, especially if you don't have the increased airflow to go with it. Running a car rich will not gain you anything except poor fuel economy.
Complete and total trash. Doug at "BamaChips.com" dyno tested a "performance module" purchased on eBay and found a 20HP LOSS.
One of my customers tested his jet chip against stock, and found the jet was a 12HP loss from stock!
Thank you guys for the valuable advice , i almost fell for the bogus deal !
Hoax
Mac Units stand the test of time, built to withstand drastic changes of temperature, moisture and erosion.
Whew! I was worried about it eroding... wonder what kind of mud slide or silting would occur in the engine if they hadn't tested it??
By running a car’s engine leaner, vehicles have gained more miles per gallon (MPG). Proven test results have indicated that by adding more gas to the engine’s fuel/oxygen mixture, an increase of up to 25hp+ can result without giving up MPG’s (1/2 mpg).
Well, which is it? Does it run lean or rich? You can't run lean and rich at the same time.
If it looks like a duck and walks like a duck and quacks like a duck.... it's just proof that there's a sucker born every minute.
Hahah, I love it. Theyre just throwing random facts that sound good in there, regardless of what the thing actually does. :rolleyes:
Lean=less fuel=more power=increased heat=melted piston.
it wont help out your fuel economy unless you are driving it hard all of the time- because during cruise your computer is focusing on the oxygen sensor, not the MAF. The computer keeps your AFR at ~14.7 based on the o2 sensors voltage
"Quality, Cheap and Fast; pick two"
