Any one running a locker in front with LS in rear? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Mkpn24
2001 Ford Explorer XLT
I picked up a new G2 limited slip and install kit extremely cheap for my rear end and want to run a locker in the front with the brown wire mod. Does anyone here already have this set up? Since this upcoming week is spring break I want to finally re-gear my truck to 4.10s. Don't want a locker in rear cause I do a lot of driving in the snow in this truck and don't want it to kick out on me thats why I went with the LS but I want the locker in the front for beach driving. What locker would I need for a 2001 explorer I think power trax makes one for these trucks?
While I'm replacing the front diff, cause I got a whole setup with 4.10s in it already, I'm also going to covert to synthetic fluid in my diffs, replace my leaking steering rack, inner and outer tie rods, upper and lower ball joints, upper and lower control arm bushing, sway bar bushing, sway bar links, and after all that get an alignment. Im running 285/70/17s on cobra r's with 3.55's and low end power sucks big time. If I have enough time I would love to finally install my snorkel and ditch the mechanical fan for a couple of electrical fans. Doubt ill get all this done because of a million other projects but it would be nice to have done before beach season.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
tenny
LI NY
2001 mounty
4.10s will be a dream come true for you then.
im running a locked front with a LS rear, with 4.56s
best thing i ever did for my truck performance, economy wise..??
RE-GEAR!!!! (when running tires larger than 31s)
Mkpn24
How does your truck handle on and off road with that setup?
jd4242
va beach
92explorer&94 ranger
I found with a locker in the front and both hubs locked (im first gen) that it pushes bad in sand and mud when turning. Takes some getting use to and planning not to make sharp turns but nothing like having true 4x4.typically a ls in the front is more practical unless you plan on having one tire in the air or going straight through some nasty stuff;)
Mkpn24
Do they make a limited slip for a 2001 explorer xlt I was never able to find one.
jd4242
va beach
I honestly dont know, like I said im first gen.im sure they do tho, sure someone will chime in.
DjDom
Moderator Emeritus
Toronto, Ontario
97 XL(imited)
jd4242
va beach
Second Gens had Limited slips in the back. None of them came with LS diffs in the front.
None of any gens came with a LS in the front...
DjDom
Moderator Emeritus
Toronto, Ontario
97 XL(imited)
Hards01FX4spt
Tacoma Wa.
2001 Explorer Sport FX4
I just bought a new limited slip for the rear of my 02 8.8 exact one as original equip. I`m putting it in this weekend.
jd4242
va beach
Believe he is referring to the front, not the rear..
Explorin'VA
P-twn
'94 xlt
I have a 2nd gen open rearend in my 1st gen, could I simply make it a limited slip by adding the S spring? Or do I need an entirely new housing?
jd4242
va beach
Need a whole new carrier...you can add a aussie tho or other lunch box locker
Explorin'VA
P-twn
'94 xlt
Carrier is what i meant. Would you recommend the aussie for use on a daily driver?
jd4242
va beach
It can be DD but wouldnt be ideal. .being VA it wouldnt be bad, I dd mine.but personally if its not wheeled more than street miles I would go LS.save some mileage on tires..I love my aussies
Explorin'VA
P-twn
'94 xlt
Yeah I've heard aussies are great. I'll probably just stay open until I have another vehicle to drive. Then I want to have a locked front and rear for sure.
Mkpn24
I've never seen a limited slip for the front of second gens that why I think I'm just going to lock it. And I have an open rear end but picked up a limited slip for the rear.
jd4242
va beach
jd4242
va beach
One thing I didnt ask was do you have auto 4x4 or awd?? If so your need to get ride of it with a locker up front, dont want it locking or kicking in on the street.also leads to you post about not wanting a locker in the rear because of snow..you wont be able to turn BARLEY if you lock the front in the snow/ice...
Mkpn24
I have 4x4 and was going to do the brown wire mod so it doesn't just kick on.
