whitestang04gt
- May 12, 2007
- Lowcountry, SC
Have anyone found long tubes for the 4.6L or know of anyone thats had some custom fab'd ?
for the stang? check bbk, mac, kooks, and i thing hedman all make long tubes for the 4.6 in a stang in fact there are even more i cant think of the brands.
K,
what is a long tube, and why do I want one?
-Shawn
They are headers, and if they are setup properly, they will extract the exhaust gasses from the motor better than stock headers. Given the limited room in the Gen3s, though, they are usually a convoluted design in an explorer, so their benefit is limited - they should still flow better than stock, but on a $ per hp gain, they are a fairly expensive, almost bling, mod.
You would be better off fitting a twin 2" system from the cats back - far cheaper, and from the cats back is more restrictive than from heads to cats. Just make sure you don't lose too much back pressure, or you will lose a lot of low down torque, so your truck may end up with more power, but it will get off the line like a tractor.
I would find it hard to believe loosing backpressure, considering its the same motor in the mustang, midpipes make the most gain over stock than a catback in the stang, long tubes give you lots of torque, sure a catback helps on these mounty's, but doing a true dual with & x crossover, should pick up massive gains. I am fixing to custom do a dual mandrel high flow catted midpipe into an x with true duals using magnaflow mufflers in the near future. I will post pics & dyno gains when complete.
Same engine as the stang, but another 500kg of weight to haul around. I'm just going on advice my local exhaust place gave me, based on his experience with all types of 4WDs, and V8s in general.
