Anyone who updated to 3.0 downgrade to go back to the official 2.2 Sync3?
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
Not sure if my heated seats issue- don’t seem to be getting very warm at all is related to the Sync3 system. I upgraded to 3.0 successfully which fixed my biggest issue which was live traffic overlays on the map- work perfectly now.
Thinking I might try to downgrade or apply the 2.2 upgrade. Anyone done this?
I have a ‘17 Sport, fully loaded without DVD Rear.
PlatinumOwner
2016 Explorer Platinum
The issue with heated seats is not related to SYNC 3. You don't even need the SYNC 3 unit in the dash for the heated seats to function.
For downgrading. 2.2 can be installed over 3.0. From there you can upgrade to 2.3. I am currently running version 2.3 as it is the most stable and bug-free version. I have tried a couple builds of 3.0 and experienced some issues.
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
Where did you pull the 2.2 and 2.3 upgrades from?
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Have you checked your Sync account? When I checked mine it showed a V2.3 update was available. I don't know if you can over write the existing 3.0 version though.
PlatinumOwner
You'll need to install 2.2 first as 2.3 added a version check that prevents downgrading. The 3.0 links online have been removed at the request of Ford's legal department. I have switched back and forth between v3 and v2 several times with no issues using this method. The official 2.3 version is what I recommend to use. There should be an update coming in March for compatibility with Waze over AppLink. I think this may be a newer 3.0 build.
2.2 Nav Version Mirror (has been removed from Ford's servers)
Dropbox - SYNC3 NAV V1 TO V22.zip
2.3 Nav for Model Year 2017
http://ivsu.binaries.ford.com/owner-package/12080212233613831570/JL1T-14G381-AJ.zip
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
Is this correct on the 2.2 download, there are only 2 files- SyncMyRide and autoinstall.lst?
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
Never mind... I see it was a folder- Windows misformatted it for me when looking at the compressed file.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
What issues did you have with v3.0?
I'm running it and all I have an issue with is the popup WiFi Update window.
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
No issues really, just want to get back to the factory releases since my reason to go to 3.0 was the nav traffic updates weren’t overlaying.
I haven’t been able to downgrade to 2.2, the USB I’m using doesn’t seem to load. When I look at other version I felt like there were 2 files and a folder with 5-6 files inside. The download posted here and verified elsewhere only shows 1 file and a folder of files. For some reason it just won’t run the upgrade/downgrade- even during my 45 minute commute the other day. Formatted at exFAT, 64GB stick.
Lambert Wang
2017 explorer ELT 2.3T
Hi, Tom, old stuff dig out .. hope you have resolved your issue , if has could you share ? or I recently found a setting / testing model for Sync , mean you press the 'CD eject ' button and ' right seek' button together, it will get into this model , not sure if this can help any .
Location
Wisconsin
Port Washington, WI
2017 Explorer Sport
My issue was the usb stick... I bought a patriot 32GB, formatted as ext and copied over the data set and presto it worked. Only difference was which usb stick I used. I’ll look to see if I still have the 2.2 zip that worked.
D Anyone use the Waze app with their MFT 3.8 or 3.10? 2011-2016 My Ford Touch / In Vehicle Technology 12
fyrfyter612 MFT problem...anyone else? 2011-2016 My Ford Touch / In Vehicle Technology 0
A MFT and MirrorLink? Anyone tried it? 2011-2016 My Ford Touch / In Vehicle Technology 3
T Anyone using Sirius Travel Link weather with version 3.6.2? 2011-2016 My Ford Touch / In Vehicle Technology 6
Z Anyone tried the SCOUT Navigation? 2011-2016 My Ford Touch / In Vehicle Technology 3
R Has anyone figured out how to get messages??? 2011-2016 My Ford Touch / In Vehicle Technology 4
I Anyone download Nav destination from Sync or run Vehicle Health Report since update? 2011-2016 My Ford Touch / In Vehicle Technology 8
E Anyone having difficulty logging into SMR today? 2011-2016 My Ford Touch / In Vehicle Technology 5
D Anyone have a problem with the "Repeat" and "Shuffle" buttons not turning off? 2011-2016 My Ford Touch / In Vehicle Technology 13
H can anyone with nav check something for me? 2011-2016 My Ford Touch / In Vehicle Technology 3
C Air Conditioning - anyone else see this? 2011-2016 My Ford Touch / In Vehicle Technology 14
B Anyone seeing these two issues with the new version? 2011-2016 My Ford Touch / In Vehicle Technology 4
N After upgrade to 2.11 did anyone loose there phone ringer ? 2011-2016 My Ford Touch / In Vehicle Technology 5
A Which 2016 sound systems can be updated to use Apple CarPlay? 2011-2016 My Ford Touch / In Vehicle Technology 15
D 13 ford exploer se lost nav when updated to 3.10.16 2011-2016 My Ford Touch / In Vehicle Technology 4
G Updated to 3.5.1 from 2.11 2011-2016 My Ford Touch / In Vehicle Technology 1
F Updated MFT December 2012 2011-2016 My Ford Touch / In Vehicle Technology 4
R SF Auto Show - No Updated MFT 2011-2016 My Ford Touch / In Vehicle Technology 2
J Ford MFT/Sync Mobile Phones Chart Updated 2011-2016 My Ford Touch / In Vehicle Technology 8
1 MFT 3.8 bug and downgrade to 3.7.11 2011-2016 My Ford Touch / In Vehicle Technology 36
