bubbadabulldawg
- November 29, 2002
- Schenectady,NY
- '92 XLT 4 Door
The wifie's 92 Exploder has developed a little knockin to the engine and it isn't worth the $2300 that Advanced & Jasper want for a reman even though I plan on keeping her(truck) around for a couple more years. I just put in a new fuel pump & sender, plugs & wires, intake & valve cover gaskets, wp & stat, ps pump & box, radiator, brakes & tires all around, radius bushings & x-member and also new 4wd shift motor just in the past few months, plus had the trans rebult 40k ago. What I'm looking for is info on swapping an engine out of a 94 into the 92 would work as a direct swap or are the engines different slightly because of sensors, bellhousing/trans etc...? I found a 94 w 74k around the corner from me with a bad trans and would buy it for the engine but don't want the hassle of moddifying or swapping ecu and harnesses if possible.
