Hey everyone, I did an extensive search and got some good answers to most of my questions, but I'm left with some specific ones that hopefully you can help me with.
My issue is this...I'm replacing all 4 of my stock 5x7's with 6.5's (non-component, just straight speakers). I don't know whether or not I will need bass blockers for them. I have a 10" Kicker sub being run off a 2 channel amp, and I plan on just using my Excelon HU to run the speakers.
The Excelon has Front and Rear High Pass Filter options built in, as well as Non-Fading Low Pass Filter and Non-Fading Phase options. I honestly never knew what these options were for before doing a little research.
I'm assuming b/c I have this option through my HU that I won't need bass blockers? The HU, if set correctly, will pretty much act as my bass blockers for the door speakers, correct?
If so, what level should I set the filters so that no bass hits them? The options are:Through/40/60/80/100/150/180/220 Hz.
Any help is greatly appreciated!!!
Thanks
Bill
Thanks
Bill
