Battery/Alternator issue? Help. | Page 6 | Ford Explorer Forums
Status
Not open for further replies.
blah..
Got the charger... jesus.. it looks like it's from the 80s..
Alright, it says:
10amp charge rate for 3-5 hours for a charge
30amp fast charge (those are on the same switch position)
and 50amp "Engine Start - To Get You Going in a hurry"
Damn.. this thing must be older than me... hahaha
Just put it on 10 amp.
Note what the amperage starts at, you don't want to run it too long at that rate.
PROBLEM! i THINK!!!
At first I thought it was condensation... this clear liquid keeps coming out of the top vents as the battery charges... n then... i licked my finger... OMG... wtf...
whats going on?
is this bad!? i brought it inside to thaw out.. n this liquid acid crap is coming out!
Help.. omg.. that was so nasty... omg.. im not liking this stuff.. i got some on my thumb and.. bah...
is this bad?!
It sounds like your battery froze and cracked. They will do this when they are discharged. That's why I was trying to get you to hurry. Damm the luck huh?
I just gotta ask,
why on earth would you lick acid off your finger?
It has a funky meter, there's a green section that's labeled charge, and to the right.. a red section, 1/3 of the screen.. says START..... and there's a needle... and it was all the way to the left on charge...
what about this acid? do i just need to thaw it out before i charge?
is my battery gonna be screwed?
it's not cracked, its coming from the top vents... and i thought it was water.. n i was bitin my finger nails.. bad habit and.... it was horrible!
Do you think this battery is bad now? Everytime I turn the charger on, that clear liquid will come out the top vents... Someone said to just let it thaw... then charge and I should be good.. omg.. this is freakin me out... and pissin me off..
well be careful with the liquid-
anything that gets wet will get a hole eaten in it. I hope none got on your carpet.
so what did the gauge read?
It just moved a little to the right. Really crappy gauge...
I've soaked up kinda a lot of this stuff with paper towels.. isn't this what holds the power?.... =\
It's an autolite 84.
What does all this liquid mean? If the battery is bad, do you think I could get it replaced? I bought it at shucks, i dont have a receipt but they should have a record of it?
i dont know what to do about this...
Called the store, they said just let it thaw out.. it's normal for this to happen if it's frozen while charging and it's a 50/50 chance it's still good... but to him it sounded fine to him.
Status
