Opera House
- August 19, 2002
- Cincinnati, OH
- 2014 Explorer 3.5L base
I had to replace a front bearing hub on my 97 with 145K on it. Best price I could fine for replacement was a Timken (same as factory) for $140 with a new sensor. I had questions about the internal construction so I pressed the old one apart on a 20 ton press. Probably took less than 10 tons to open it up. Supported the three hole mounting flange and pressed from the back on the spline shaft. It easily popped apart with the speed gear mounted on the back bearing. Shields popped out without damage. Wheel side bearing was slightly damaged with contaminated grease, what there was of it. No reason why you could not press it back together.
It is obvious that this damage could have been prevented with greasing halfway in its life. There is no reason why the speed sensor can not be pulled out and greased through that opening. Some conical adaptor on the grease gun would work nicely. One word of caution. These sensors do not come out easily because of rust and you should be prepared to buy a new hub if it snaps in the hole. As long as you don't go wild with pressure and speed the seals should not pop out. Wheel side shield obviously gets more wear.
Something you might think about when doing brakes at 70K or more. Both bearings are conical roller bearings and the torque spec for the shaft nut is to keep the bearings from seperating. No pictures, this is Theatre of the Mind.
CAUTION: It is probable that sealed bearings contain polyurea grease because of the long life properties. These are not compatable with the more common lithium greases. One of the results is the grease thins several grades lower and causes bearing failure. Check the contents of your grease first.
