OverkillYJ
- September 1, 2014
- Philly
- 1995 Jeep YJ (Wrangler)
Hey guys! I already have a Wranger and a 302 Im dropping in from an explorer, so I dont care about wheeling this explorer. Thats what my Wrangler is for and one offroad vehicle is expensive enough.
I need another vehicle with more interior room just for car seats and stuff. I am only getting a 5.0 Explorer. Problem is, I am having a hard time figuring out the best year. The one I'm currently building to drop in my Jeep is a 2001 with the GT40p heads, but Im running it wil an A9L EEC from a Mustang GT, and reverting quite a few things like injectors to the older style. Basically, motor completely self contained separate from the rest of that vehicle.
I know in 97 they stopped using the normal injectors and went to those white lower lb injectors which use a different harness. They also changed the heads though to better heads with more compression.
My plan is to make this Explorer I buy just FAST. Thats really all I care about. AWD with a built V8 will be fun on the road. I need leather interior because I do a ton of mechanical work and build axles, so Im always greasy and dont want to stain a cloth interior.
Im mainly concerned about how much work is going to have to be done with each upgrade though. The older EEC's basically self adjust using their table regardless of what upgrades you do to it. With the Explorers I am not sure what will happen if I pulled the orange stock injectors off the motor and stuck in higher lb ones though. Also, if I do a cam upgrade, how will it react?
When it comes to taking these and making them produce a lot of HP instead of the torque their designed for, which computer will be the most friendly? Also, how does that high pressure fuel line with no return act when you start changing parts out?
A lot of what I have read googling this has people saying just get the newest 01 because the electrical kinks were worked out more. I can fix all that stuff though. I own a full service shop I use for whatever I feel like. Its my toy building place. Im more concerned with how big of a pain it will be to get the motor to accept the upgrades and run properly. I know it will need a tune no matter what I do. Im more worried about having to add a return fuel line for example if I have an 01 and want to upgrade the injectors.
Also, things like EGR delete I am sure are more complicated on different versions. (track use only of course). That is one thing I like about the gt40p heads I have is no EGR. I have a ton of 5.0 parts lying around. Piles of stuff literally because I sell a lot of stuff to mustang guys. I would still rather start with the most friendly version possible. Im guessing it may be the 97 I want. I believe that is the last year they used mustang style injectors, but am not 100% sure. I also was not sure what headaches having a fuel rail with no return on it may present further down the road. The high PSI has me curious if that will give me more to do also.
So if you were going to buy a low miles 5.0 AWD Explorer or Mountaineer to upgrade over 300HP, which one would be the best candidate?
Also, I am building a 393 since they are dierect bolt in and only weigh 50lbs more, but that will probably go in my Jeep one day. Not sure. Maybe into the Explorer. Depends on what I can squeeze out of it without upgrading to a Megasquirt system or something too expensive.
Thanks for the help
Thanks for the help
