Latest Dyno results with my Ford Motorsport SVO Powerdyne supercharger
So finally was able to do some tuning with SCT instead of what they were using before.
The second picture shows the run that was done before the X pipe and removal of old stuff between the headers and Borla mufflers. I was told during this Dyno run they were able to lock up the converter in the tune for a better consistent pull.
So this run at the wheels showed 293.09 HP and 355.49 ft lb of torque. Since I cannot seem to find a completely accurate drive train loss percentage for a 5.0 L Explorer with the 4R70W transmission and Borg Warner all wheel drive transfer case I’ll use 25% and 30% as these are the two that seem to be stated the most. 25% would be approx at the motor 391 HP and 474 ft lb torque. Using 30% - at the motor approx 419 HP and 508 ft lb torque.
The 1st Dyno sheet shows after the X-pipe was completed along with the other things. I was told that apparently during this Dyno run they were not able to lock up the converter so they had to ease into the pull to keep it from downshifting into 2nd. There also seems to be a loss of torque but I was told that this is not necessarily 100% accurate but I’m not sure I understand why. Even with that the torque is still higher than it was before these two Dyno runs. So this run at the wheels showed 303.07 HP and 336.51 ft lb of torque. Again, since I cannot seem to find a completely accurate drive train loss percentage for a 5.0 L Explorer with the 4R70W transmission and Borg Warner all wheel drive transfer case I’ll use 25% and 30% as these are the two that seem to be stated the most. 25% would be approx at the motor 404 HP and 448 ft lb torque. Using 30% - at the motor approx 433 HP and 480 ft lb torque.
I’m still trying to understand the technical aspect of these results as well as the explanations I have been initially given. What I can say that is driving Big White is quite amazing and a blast. It’s incredible to see what a difference all of these improvements have made to my Explorer.
View attachment 430826 View attachment 430827 View attachment 430828 View attachment 430829
