Thanks.
I measured it all out a few weeks ago, and I know how much shock shaft I need showing at ride height with them angled in slightly (4"), to get the most out of them. I was looking at pictures of a stock Explorer's rear axle, and I think I can get close to the original angles, but come off the lower half of the axle to protect the shocks. Biggest issue I can see already will be keeping the shocks close together on the axle, but not having them contact each other. I saw some pics on the interweb that showed mounts like mine with a spacer in between and one long bolt for both shocks. I think I can make that work, but the mounts will have to be angled on the axle and at the top to save the bushings. Also noticed that the shocks I have use 1/2" bolts on top mounts and 12mm on the bottom. Need to press out the old sleeves for the bottom mounts and get some 1/2" sleeves in there to match the mounts.
My goal with the Explorer is to have an all around off-roader that does every type of dirt well. I am still surprised when I take it out how well balanced it is, and how it seems to be almost exactly what I was shooting for when I started. I thought when I did the SAS I would lose some of the go-fast type wheelin' capability, but it seems the opposite. The only thing it doesn't do well is go up long, steep grades on the freeway. Tends to get a little warm. I edited the post 789 to add an electric fan upgrade.
Really, I could wheel it as it for many happy years, but what would be the fun in that?? Looking at the rest of the Expo, the rear shock mounts look a little ghetto, and I know they will eventually fail.
