- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Pulled the power steering pump reservoir to reseal. Kit has everything needed, even the cap O-ring. I was unaware that all you have to do to remove the reservoir is remove the pressure valve where the pressure line attaches. Unscrew that, and you can wiggle the reservoir off the back of the pump. Replaced all the seals and O-rings (they were all shot), bolted it back up and it promptly started leaking out of the center of the pressure hose fitting where it attaches to the reservoir. I noticed some fluid on that area before I took it apart, but I was hoping it was from the pressure valve leaking. Oh, well, off to the parts store for a new hose. I should have replaced the pressure hose when I replaced the steering box and I am now paying the price for being cheap.
Would using a rock ram remove a lot of that load? It seems like it would, as it pushes / pulls on the tie rod as the steering is pushing / pulling the drag link. No, I have no plans to get a rock ram.
Mine would stay since I run a hybrid radius arm set up where the upper links are in toward the center of the rig than the lower links. So it may sag a hair to one side or the other but it could not fully fold up.
Also may seam like a lot of side load on the steering box to hold it from folding over at a rest but think of the pressure the box gets when trying to turn twisted up on rocks.If you took the trac bar off I bet you could have one guy easily hold the rig centered from flopping, but one guy cannot even come close to turning the front tires at a stand still even with pushing on the outside of the tires which has WAY more leverage than the steering knuckle. Yet the box can move them with ease at a stand still. Lots of pressure!
