- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Problem with the dome light was the wire plug in the driver side A pillar. I tweaked the metal tabs inside the plug and got a solid connection.
Decided to fix something else that has bugged me since I installed the NP231 transfer case. I pulled the speedometer gear housing out because the old speedo cable was twisted off inside the housing after it the cable melted. I pulled the cable end out and got to thinking I should change the speedo gear while its out. The speedometer reads about 10 MPH fast at 60. It has a 36 tooth gear in it right now, but think I need to go up to a 40 tooth. Nobody makes a size chart for a NP231 in a Explorer....go figure.
The charts for a TJ states I need a 40 tooth, but is there a difference vehicle to vehicle for gear ratio/tire size/speedo gears?
