boominXplorer said:
put it this way, I have soa in rear and my front is about an 1'' or 2'' higher. Did the spindles you got have a place for your abs sensors?
yes they did but the one on the drivers side did not want to go in all the way and allow the bolt to thread in..
after about an hour later and a few dremel wheels later still could not take enough off in order rto get the bolt to go in.. so i drilled it out totally and put a nut and bolt.. should work fine i am hoping,,so far so good....
now i have heard of others that had to grind the bottom of the spindle a little bit in order to allow a full turn.. i guess especially when tt is maxed out...
i kinda wish i did because where mine is now my left turn radius is noticibly less then when i turn right...
it looks like you have driven it from the pics? looks like you are in front of a
store.. how does it drive so far.. do you feel a huge dfference with the larger tires.. lucking i have a 3.73 limited slip. but still want a better gear...
i am guessing with 35's you will fid a good amount of ifference with power??
now see i was afraid to do the SOA for fear of the rear being higher than the front. i guess i should have waited to see yours...
any way i like the way it looks and that is without the body lift right???
do you rub now if you have no body lift installed??
sorry to be so long...
thanks
David M
