keithisg
- December 3, 2010
- Elizabeth City, North Carolina
- 1994 Ranger reg cab 4.0
So after reading I'm sure this has been posted a million times but I could do a budget suspension lift using the following
SOA
5.5 Springs
Shock absorbers all around
Pitman Arm
radius arm brackets
Extended Radius Arms
Extended brake lines
Alignment?
I feel like if I pieced this together using Skyjacker parts it would work out to be cheaper. It would balance out to be about correct right? If the back was a little lower I could throw some shackles or something up there to boost it up. If I remember reading correctly this is exactly how Superlift does there 5.5 lift, but not to sure. I hear better things about skyjacker parts also, and being able to order the correct drop pitman arm would also be a benefit as I understand the regular lift does not come with the correct one.
SOA
5.5 Springs
Pitman Arm
radius arm brackets
Alignment?
