- June 16, 2003
- Humboldt, KS
- 2000 Mounty
Hi turdle,i see you have a lot of experience with cam sensors.I have read the posts.I have a book on my 98 mercury 5.0 as well.I have been trying for weeks to re-align the sensor because it had gone bad.I have tryed 30 different positions and can't hit it by accident.I have done everything by the book.The only thing that does not jive is tdc does not match the mark on the harmonic balancer.I can visiualy verify tdc without a problem,but it is about 60 degrees away from the sensor mark on the harmonic balancer,this has to be the problem.What should i do?The truck has a lot of miles on it,240k.Could thier be that much slack?Any help would be much appreciated!
It could be that the harmonic balancer has "slipped" from the crank pulley, as they are a 2 piece unit with a rubber internal hub holding them tightly together. Mine had slipped in my original engine. I needed a new unit anyway for various reasons so it didn't matter but I did make a note of it. Mine was probably 10-20 degrees off from consulting the photo in my head.
There is probably little mis alignment due to timing chain stretch also.
If I remember correctly the crankshaft timing sprocket key-way faces straight up when #1 is at tdc. So, you might want to pull the pulley off, check the actual crank position and compare it to the crank sensor trigger and timing mark. Let us know what you see.
edit-Don beat me to it in other words--lol
