MalcolmV8
- June 29, 2005
- Kansas City, MO
- 05 Tundra DC
Hey Guys, the answer to this is probably available in a search but it's not working right now. I got a database error and it said an email was sent to the administrator.
Anyhow, I went down to the driveline shop this morning so they could build me a driveshaft to work with the AWD BW4404 I have in my Ranger. Turns out those CV joint driveshafts are pre-made. You don't just purchase the CV and add a shaft as I was hoping. The driveline shop was skeptical about been able to successfully modify a stock Explorer front drive shaft to work for me but they said they'd give it a try if I want. They really didn't like them though. They said they see so many of those coming in because the CVs fail.
Even if I do find a cheap used CV front drive shaft and have it shortened or lengthened to fit my truck if ever I have a problem I have to get a new custom shaft made. Not fun.
So we went to look at my truck and the front yolk or flange or whatever you want to call it appears to be part of the output shaft. I recall from old posts I've seen on here that there was another variation of the 4404 that had a regular U-joint up front. Is that true? Will I be able to get a hold of the front output shaft from one of those and just swap it into my case?
Thanks for any insight.
Malcolm
Malcolm
