Center Console Display Removal | Ford Explorer Forums
RandomNerd2000
South Carolina
So, on my 2001, I want to replace the center console display, there's nothing wrong with it except the coating is bad rough and there's a good one at the JY I can get cheap. Only problem is, how do you remove it? I've never done it before.
If I am correct in it being basically the same as the non-display plastic storage cubby version...
The part of the center console that the display is on is held in with plastic clips. the display and button modules are then bolted / screwed into that surround.
Alright, thanks for the info.
