Chain Lightning - 2003 Centennial Edition | Page 2 | Ford Explorer Forums
Phew
Here is the current mod list, specific to the Coyote & 10R80. This specific post will get updated as I remember specifics. Once complete, I'll add it to the first post on the thread.
UNDER THE HOOD
Gen3 Coyote, stock (Mustang GT spec)
Battery relocation
Install Coyote PCM & fuse box
Custom oil, trans fluid, fuel, and coolant lines
Custom battery cables
Stock Explorer radiator & overflow bottle
Custom radiator & AC condenser mount (stock Explorer trans cooler removed)
Derale 16830 dual fan & shroud kit, with two Derale 16759 controllers (notched to allow for alternator clearance)
Customized Explorer 4.6L oil pan w/PBH pickup tube
Custom air intake w/K&N filter
PBH accessory drive w/Explorer PS & AC
Relocated oil filter
Added trans fluid filter
Added oil & trans coolers
Tom's Off Road Bronco Coyote swap headers
Removed IMRC gear (variable intake runners)
Removed most Explorer wiring related to stock engine and trans (see below)
Repurposed Explorer starting circuit for Coyote, including PATS
B&M trans dipstick
UNDERSIDE
Monster Transmission Gen3 F150 4x4 trans
Stock Borg Warner 4410 AWD transfer case
Custom transfer case adapters (housing & shaft)
Torsen limited slip rear differential
Relocated stock trans crossmember
Full custom exhaust
Aeromotive 340 dual fuel pumps
Custom mount in stock tank
TRUCK MOD LIST (Specific to Coyote)
Wiring: removed nearly everything associated with stock engine and trans management from wiring harnesses. Explorer BJB is untouched.
Removed:
- Fuel injectors
- Coils
- O2 sensors
- Cruise control
- Entire evap system
- Idle air control
- Sensors: crank position, cam position, knock, throttle position, MAF
Kept:
- Starter solenoid trigger (the Coyote starts with the stock Explorer key and cylinder, and still has the stock Explorer PATS)
- digital trans range sensor wiring (prevent starting out of park or neutral; wired through Lokar shifter)
- Reverse lighting
- AC clutch
- Crank position (to tap into Coyote CPS)
- Output shaft speed (to tap into 10R80 OSS)
- cylinder head temp, including connector
- oil pressure sender, including connector
- Fuel float and wiring (pump removed, associated wires clipped)
- Various vents and ports on stock tank plugged
- Don't recall which wire offhand, but there's a wire from the Explorer PCM that is hot in start and run. I use that to trigger the inputs on the Coyote PCM.
Frame: small notch in crossmember behind transfer case to allow clearance for rear output flange; new tapped or threaded insert holes for trans crossmember in frame. Minor additions to trans crossmember to allow for relocated mounting holes.
Floor: None. No sheet metal mods anywhere, in fact.
Fuel tank: custom hat for Aeromotive pump assembly
Functional factory fuel, temperature, voltage, & oil pressure gauges. Speedo and tach are not working yet.
Removed stock throttle cable and pedal. Mustang throttle pedal mounted on 2 of 3 mounting studs for stock Explorer pedal, with very minor mods to the Mustang pedal for clearance. Lost adjustable pedal capability, as the motor for that is on the throttle pedal and can't easily be adapted to the Coyote throttle pedal. There is also a small metal bracket spot-welded to the Explorer floor that had to be removed.
Removed stock column shifter, indicator, and brake shift interlock. Steering column lock still works.
Lokar shifter is mounted to the inner center console structure, with careful cable routing to avoid the Explorer restraint control module.
As I said above, this specific post will evolve over time as I either remember things I did, or do new stuff.
