clutch
Noved87
Points
Kelso, Washington
'94 Sport
i went through a clutch in 3 months (no deep mud/water anything) it was completely gone, down to the metal :eek: does antone know who this would happen or has it happened to you before? how can i prevent this happening again? the shop which has been around for almost 40 years hasn't seen anything this bad before.
ride the clutch a lot? :p
Ive actually had a clutch go in a few months before. It was a LUK regular clutch. Sometimes they are just bad out of the box, maybe that was the case.
You can try Centerforce. A bit pricey, but it should last longer.
make sure your flywheel gets resurfaced too, they might of skimped on that and you ended up with a dead clutch sooner.
ive had my clutch in for almost 50,000 miles now. I'm crossing my fingers it doesnt go anytime soon :D
i never ride the clutch. not much wheeling on this one or towing. i took it to a shop and had them do it so it has a 12,000 mile warranty for 12 months. i was wondering if anything was wrong with my tranny to cause that much damage. the shop said we installed it perfectly.
Maybe the flywheel wasn't machined?
it was brand new. i do everything right on my X
Bad slave? Not fully releasing causing clutch wear? Maybe?
I think they just used a crappy clutch though.
I'd have them tear it apart under warranty. Even the best shops can screw up sometimes.
shop said slave was fine. now I have a 12 month 12,000 mile warranty on it. thank god
Rear main seal leak?? Oil on the Clutch will eat it up. Happened to me once
3 months is still odd.
I suspect the clutch was dragging at all times (never fully disengadged) or something with the initial install was not right.
When I bought my X it had recently had a new tranny and clutch installed-- whoever did the installation didn't bleed the clutch correctly so it was dragging a lot. It wouldn't surprise me if the shop you used didn't bleed it correctly. There's a complicated ritual in the FSM involving two people, a small screwdriver and a lot of brake fluid. It must be performed precisely and repeated several times to be effective.
So far the possibilities are...
- Flywheel went un-resurfaced
- Slave cylinder wasn't replaced or was worn, causing the clutch to drag.
- New Slave cylinder wasn't bled correctly.
- Engine oil from a leaky seal (maybe your rear main?) caused clutch to wear.
haha, cool info.
Maybe it was a poor quality clutch? Maybe you got the defective one out of the batch? Maybe the shop dropped it during installation? Damaged during shipping?
Theres too many possibilites.
thanks i was just wondering how to prevent it again
i now have to go back to the shop today. they didn't hook up something right in the T case. different shop next time.
I wouldnt be towing anything with that sport , not if its having clutch issues :)
