i finally figured out what my problem was and how i think bleeding a clutch on these badboys can be done. here's the procedure that i think should be done, assuming that everything works.
1)bench bleed the master cylinder first, then WITH the line to the slave that has the check valve in it to make sure it's good. make sure you hold the line upside down so air can travel up and out of that line. after you have fluid in it, pump a few times, then open valve, depress rod, close valve, release rod, repeat until you can't see any more bubbles.
2)install in vehicle, make sure the pedal is hard as a rock with your hand, not foot or else you could break the master cylinder. if it isn't, it's either a bad master cylinder or you didn't get the air out.
3)attatch hose to slave and crack bleeder valve for a few seconds then shut to relieve some pressure built up in the master cylinder.
4) pump pedal 5-10 times, wait 1-3 minutes and repeat 3 times.
5) crack valve, depress pedal, close valve release pedal and keep an eye on your fluid level. repeat this about 5-10 times.
6) check pressure. repeate steps 4 and 5 until bled, if still no pressure, start over.
basically i think if you use that procedure and keep trying you should get it. like 410fortune said, air can get trapped in that "U" shape, which is what happened to me. i guess every case is different, but by following that you should be able to get air out of the master cylinder, the line and the slave cylinder.
anyone got any further ideas on why my trans won't go into reverse?
