rockylaurence
- January 23, 2000
- Lakeland, Fl
- 93 Sport
I installed a 410 cam 3 yrs and 50K miles ago. The motor had severe failure last week. I found that all the exhaust rocker pads had worn through!!! I did everything correctly on the install-I talked to Doug, Comp Cams techs, etc to find out the correct valve lash. I had the high performance springs installed by a speed shop and the seats set up, etc. What caused only the exhaust rockers to fail!! Are the cast rockers too soft? This is CRAZY!!! :fire:
