Hi Everyone,
I'm pretty new here but I have done a lot of searches and read quite a bit about the differences between the 5.0 in the Explorers and the 5.0 in the Mustangs but I haven't seen much on this specific issue. Heres my plan:
I'm planning to get a 00-01 Explorer/Mountaineer 2wd V8 and possibly swap in the following motor:
I have a complete 306 motor from a 93 mustang that needs new rings etc... This motor is built with custom cam, ported GT-40x Aluminum heads, Performer RPM intake, 75mm TB and the big mod - Vortech S-trim supercharger. This motor put out 560 RWHP when it was healthy.
Where are my problem areas going to be?
Will the Throttle cable hook up?
Will I have any clearance problems with the accessories or the supercharger set up?
Are the fuel systems the same configuration?
How about using the EEC-IV computer in the Explorer?
I know I'll have to use the Explorer oil pan, engine mounts, get Explorer headers and possibly tranny/cooling upgrades. I would really like to use the complete motor as is with accessories and EEC-IV computer to run it as already have a custom tune and this way I can avoid the DIS compatibility issue. I'll also go with an electric fan if need be. I likely will de-tune this motor a bit so I don't have to do a complete custom fuel system like was in the Mustang.
I have a similar supercharged 347 in a 95 mustang if for any reason this swap would be much easier due to packaging and accessories but I'd rather not...
Thanks in advance for the insight, I have to believe that someone has probably done this before
