Bigmellon
- November 13, 2000
- Michigan
- '01 Explorer Sport Trac
I thought that maybe some of you out there would be interested in possibly smoothing out your ride a bit with bigger tires. I know I still have some vibration at speed!!!
Continuous wheel balancers are used heavily in the trucking industry to get maximum life out of a set of tires. It allows for dynamic balancing of the wheel as you drive!!! These are a device that bolts between the wheel and the wheel hub on your truck. They have a fluid and heavy metal ring that balances the wheel through centrifugal force. I think they can compensate for between 10 and 15 oz. total. That means that many of us wouldn't have to even spin balance the tires!!! That is unless they are already badly cupped.
There is a company that has now released a balancer in a 15" wheel size. I think these were used before on a lot of Jeeps. Thankfully, we share the same 5x4.5" bolt pattern and therefore we have a match!! Unfortunately, they had been having trouble with fit related to the disc brake calipers. I think they redesigned it to fit better.
I ordered a set and they will be here in just a few more days. I can post more information early next week with how they work and if I like them.... It does sound tantalizing, doesn't it?!!!
If you want to check it out in the meantime, here is the company link:http://www.centramatic.com/
Otherwise, you can do a search for continuous wheel balancer... There are a few companies that make them, but only this one that has them in a size that we can use....
