cruise control | Ford Explorer Forums - Serious Explorations
cruise control
deamon3
Wisconsin
94 Eddie Bauer
How hard is it to actually fix the cruise. I imagine they all break in the same way. Mine doesn't work , you can press the buttons all day and they do nothin.
mine was the same way, check under the hood. theres a plug that should be attached to what i believe was the master brake cylinder. theres a thread on here ill find the link for you it has pictures. also check all the fuses (just note on a ford its called speed control not cruise control, took me awhile to figure that out when i was trying to find the cruise control fuse in the manual.)
The module behind the glove box is what fixed mine... I paid 5 dollars for it at Pull a Part
