josh40601
- January 17, 2011
- La Mesa, CA
- Ranger & Explorer
So, like I mentioned in April, I took the truck back to my buddy Jordan up at Coin Jar Off Road in San Marcos. He's done a lot of stuff on this truck, and his pickiness is something I really like. He is kind of set in his ways on some things, but that has turned out pretty good when it comes to this truck.
I say that disclaimer because my original goal with taking the truck back to him was just to have the wedges welded on the smooth tube Dana 44 (one without the cast wedge inner C's) and reuse the rest of the setup I already had other friends make for me.
Well... That didn't happen. Jordan wasn't comfortable putting the new axle in using radius arms with the bushings. He said we could do radius arms like the XJ's run, or we could just do a 3 link. He said he could get it to fit, and knows he could dial in the suspension to what I want with that setup, so I told him to go for it.
He sent me this last week. He doesn't take a lot of "during" pictures, but here it is before he redoes the steering.
After taking out the radius arms, he rebuilt the new dana 44 with all yukon parts from Ruff Stuff (Thanks Morgan!), added a new steel diff cover, added a truss, and put the 3rd link directly above the driveshaft. Everything has been cycled with a modified JK driveshaft for mock up, but Adam's Driveshafts will be building my new ones. The only clearance issue was at full bump on both sides, the 3rd link mount barely touches the JK driveshaft. Adam's will be using the TJ sized tubes instead of the JK's, so that won't be a problem once it is mounted.
As you can see, the shocks are spaced a bit off the axle. Even with that height of the mounts, the lower mount is still almost 3" lower than the old setup. This allowed for 1.5" of preload on the shocks, and it is still sitting low in the front. As you can see here:
So there are still a few more things to do. I also decided to go away from heims on this truck, due to the amount of on-road time I plan to have, and well, heims suck on road. Or at least the ones on my trucks do. I'm sure some of you love that ****, not I. I called up Ruff Stuff again and ordered their Y-link steering kit with a set of their tapered inserts. I also picked up a set of used (very used) knuckles from garage fab out of New York. A set of lifetime warranty ball joints from Orielly's and new warn lockouts were dropped off Sunday and the last bit of parts from Ruff Stuff should be there this week. So that brings you all up to date. And hopefully the last time I'll have to change the front suspension.
things left to do:
- Clearance the engine cage to access the master cylinder better
- Clearance the engine cage to access the blown blower motor resistor
- Clearance the engine cage to fit better around the air intake
- Driveshafts (Hoping for a 2 piece rear so I don't have to move the gas tank. We'll see what Adam's recommends)
- install the new steering setup
- Probably a lot of other little crap, but a whole lot less than it used to be
things left to do:
