mitchx3
- March 28, 2009
- mn
- 1998 Sport (ohv/5spd/4x4)
I have a 1998 sport (4x4, manual, ohv) and want a front diff that's other-than-open.
Was waiting for Torsen to make another run (Torsen® Traction) but they've pushed the date out now from summer 2023, to fall 2023, and finally to "maybe in 2025".
I had seen suggestions that normal Dana35's would fit in the Dana35IFS case but also saw some indications it wouldn't work (some mentioning axle-retention mechanism (c-clip vs circlip)). I decided to give it a shot since I couldn't find good documentation either way. I was hoping the case would be right and I could modify the axle stuff to work.
So I bought:
A front diff/carrier from a 2002 ranger (4.10 gears)
A set of CV axles
A Dana Model 35 - M35 Trac-Lok Posi Unit (M35TL-27-354UP or 74210X)
A case spreader (the common case spreader listed as for Dana30-80 has really big nubs that don't fit the Dana35IFS case (small nubs), but it's probably possible to drill/tap for a 2nd set of smaller nubs )
Dana35IFS on the left, Dana35 on the right:
As you can see, the Dana35IFS is about 3/4" smaller from bearing to bearing.
So I bought:
A set of CV axles
