mlucas
- December 19, 2010
- Mississauga, Ontario
- 2006 XLT 4WD
Hello All,
I have a 2006 Explorer XLT which has a dealer installed remote starter which does not start the engine. When I push the button, the horn beeps once, there is a short pause and then the horn beeps twice and then nothing. Normally after the second set of beeps, the engine would start.
When I did my test from inside the truck, I noticed that the security light on the dashboard starts to flash quickly and the truck appears to be "locked out". It takes 15-20 minute for the system to reset itself and let me use my key to start it.
I've read most of the postings I could find on the forms. I don't believe that my model has a PATs system as the key and the door lock/unlock remote are separate (not like my wife's 2006 Fusion keys).
It looks like my problem might be that the remote starter has lost it security code to start the engine. I tried to reprogram it starting the truck and then turning it off, removing the key and within 10 seconds, pressing the button on the remote starter remote. I also tried without starting the truck, just turning the key to position 3 and then off, remove the key and press the button the remote start. (See: http://216.198.221.184/forums/showthread.php?t=270380&highlight=Remote+Start, and http://216.198.221.184/forums//showthread.php?t=258688)
It seems like the bypass link between the remote start and security system is not working. I'm an electronics guy, I can follow wires and use a test meter. Does anyone know where to start looking for the bypass module? Is it under the dash or under the hood? Any trouble shooting tips would also be helpful.
If I need to replace the bypass module, does this look like the correct part:
http://fparts.dealerfit.com/store/ford-explorer-remote-start-securilock-kit-prod831_8540.php
Thank you,
Michael
Thank you,
Michael
