Decent Replacement Clutch | Ford Explorer - Ford Ranger Forums - Serious Explorations
Brock94
Milford, CT
1994 XLT
Well, my clutch is slipping-- as far as I can tell it's because of oil contamination from a bad rear main seal.
I'm planning to replace the clutch (and seal) myself, but wanted your input about what is a decent clutch to buy.
I found an eBay deal for $210 +$25SH for:
1. LuK Pressure Plate
2. LuK Clutch Disc
3. OEM Release Bearing
4. OEM Internal Slave Cylinder
5. OEM Pilot Bearing
6. Alignment Tool
I'd like to replace all these parts-- is this a decent deal? Are these parts good? I don't want to spend a ton on the best, but I don't want junk either.
Would I do better if I buy stuff from CarQuest or Napa?
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
LUK is the brand Ford put in there on yours. It's much better than going with a parts store brand. I went with the LUK Gold.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Dial a Clutch sells LUK clutches. Here's there web address Dial A Clutch
If you end up ordering from them online a little bit will come back to help the site. :thumbsup:
Brock94
Milford, CT
1994 XLT
Cool, I'll check it out.
