do ranger lifts fit on explorers? | Page 2 | Ford Explorer Forums
RCD, that would be the one. Its a coil over conversion kit, and totally gets rid of the t-bars. You might have to do some fabrication to make it work, but I really have no clue.
y'all with the 3"bl i have some questions i have a 96 2dr sport x 5 spd and im going to install the bl what knid of tips/tricks if any have y'all learned from yours? what size tires could fit, 31 mabe 32s it will be seeing alot of off road use, im going to replace the rear springs with those from a 4dr this weekend as well put in a new transfer case, clutch disk, pressure plate, bearings and seals, anyway its going to be a long weekend thanks for the info.
if ur doing the 4dr leaf pack u should just go ahead and order the shackles, do that same time
as for tips with the body lift, lots of extra washers , and when drilling out the threads, use a smaller size and work up to the 1/2, will prob be easier, i did that for the last 4 bolts i had to put through, went like 3 sizes smaller then got to 1/2, worked for me i dunno, maybe the bits just suxed, good luck,
