2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
head gaskets
I've already purchased and received a set of MLS Fel-Pro head gaskets. Rock Auto had a sale a while back so I took advantage of it. I also purchased a set of their head bolts for the same reason. I thought about buying a set of reusable ARP head studs/nuts but they are expensive and I don't know if the heads can be removed/installed with the engine in the vehicle with head studs. The machinist will evaluate the block and head surfaces and the head gaskets. If he thinks the compression ratio will be less than what I want he can mill a little more off either or both. I'm hoping to get all of the internals right the first time so I don't have to pull the engine or take it apart again.
