99awd50
- February 2, 2009
- The Bay
- 99 5 liter
So I purchased this 98 ...5 liter explorer with 91k miles, gold, awd of course and it has a blown something (headgasket). There were mass amounts of water in the oil. The oil looked like cake batter when I drained it. took the heads in to check for cracks and straightness. Ended up getting a valve job done, heads were fine, surfaces cleaned up and the bill was 250 dollars. The only thing that I could see where water went into the oil was possibly the intake to head water port on the front of the intake. the headgaskets themselves looked relatively fine. But get this...one of the water pump/timing cover bolts that bolt to the block where the water goes in and out of the block was completely loose and was thinking maybe thats where a seal failed and water dripped into the oil pan.
Tearing down the motor was straight forward. drained any coolant that was left. removed coil packs, wires and plugs, removed throttle cable, upper intake and all attached. removed lower intake and all the valve train to include the valve covers. removed the stock headers. removed both sides of accessories to include water pump, balancer and timing chain. removing the radiator was a *****. did lots of cleaning of all the nasty oil crud that was present, especially in the valve covers and the lifter valley. i cleaned all surfaces of the block, reinstalled the heads with new arp bolts. installed all the now clean valvetrain, torqued the stock rockers to 21 foot pounds. installed the lower intake and hopefully did not slide the lower too much to cause the RTV bead on the back of the block to not keep oil from escaping. installed all the connections, sprayed the throttle body bore with wd-40 because it looked a lil moldy-ish. of course i did not list alot of the small stuff like the crank sensor removal. The one delima i figured i would have issues with was the water pump bolts. i did have to have my cousin help the bolt out as i wrenched it out. need to retap those holes still then install better bolts. I did break off a intake bolt in the head. it was front front driver side bolt. the machine shop removed that during the valve job.............................................................................................................. The only really things left to do is run a tap in all the upper timing cover/water pump bolt holes, redrian the oil from all the brakes parts cleaner that i sprayed in the lifter valley. Install a new water pump, install all the hoses, all the accessories and brakcets, install the radiator, fill fluids, check all connections and fire her back up. Hopefully this will happen by Saturday morning.
......Of course after the first couple of hot cycles i will drain the oil while still hot and change it so ensure all the nasty water in oil mix has been eliminated. This headgasket job was obviously similar to a Mustang but a lil more of a pain in the ass with it being a explorer and having to get on a step ladder for the rear of the motor access.
......I still cannot deicide if i want to keep this thing when done or sell it and triple my profit. I do daily drive a 2003 Cobra that makes 461/454 at the wheels and has 89k miles. so maybe its time to park the Cobra and drive the explorer. I need to pull the Cobra motor and do a couple of maintenance things to it to include another clutch. anyways.. i will post pictures of the progress in a few days.. thanks.
