Don't buy this pre oiler | Page 2 | Ford Explorer Forums
Here is a email I just sent
I need you to Call me my name is Donald stamper 1 919 964 x..
Your kit don't include the timer any more why???
I recommended this kit to lots of people
I am getting messages
from people complaining that the kit is missing parts like the infitec timer
Without the timer this kit is useless it just don't work on timing tensioner s in our explorers without. The timer .
I. ask that you remove my name and review from your website asap I will call the better business bureau I if it's not
Here is an email I got this morning....Good evening!
I recently installed a pre-oiler system like the one you have mentioned on here in past posts from autoenginelube.com. I was wondering if you could share your experience with me as I'm not sure my install is working correctly.
When I run the engine, stop it, and then go to restart it, the gauge jumps up just like you have described and everything is great. However, when it has been shut off for a period of time (as little as it would take to fill up a gas tank or run into the store) when I go to restart it the pressure does not show on the gauge and the check gauges light does not extinguish. Does yours react this way as well, or does it always register pressure?
My kit didn't come with everything yours did for some reason. There's no pressure gauge on the tank and there's no controller for the valve. It's just wired to come on with the accessory and stay on until the car is shut off. However, I did pull the tank out and manually fill it with air to pressure test it and that seemed to hold pressure for over a half hour or so with no issues. Wondering if there just isn't enough volume there to pressurize once all the oil has settled out of the top of the engine?
Any help you can provide would be greatly appreciated. I haven't been able to get a hold of the guy who sold it to me...
If you want to explain you can comment here Don't buy this pre oiler try to save face
And your phone number don't work why??? do you have a new one????
And no we can't run any other oil than 5w 30 in our trucks
Why remove parts from the kit and then Jack up the price $100 seriously I have sold a bunch of the kits for you and now this
REMOVE MY NAME FROM YOUR WEBSITE NOW
sincerely don and jess
just to update this: autoenginelube is now a different website. no more preoilers from them! AUTO ENGINE LUBE - AUTOMOTIVE RESOURCES
It's okay I figured out how to make a pre order Out of a oxygen tank or Paintball paintball tank some brass fittings12 volt timer delay relay and a fuse with a switch No problems
Do you know in case someone needs to know in the future
good to know!!! do wonder what on earth happened to them? its alsmot as if its a mystery :D
A pre-oiler would give me peace of mind - and save my battery. Figured I couldn't afford one though. Are those all the parts you need and not the kit?
