SupaSwope
- August 5, 2016
- Florida
- 99 Mountaineer 5.0 RWD
So I went to the Junk Yard yesterday and pulled a door actuator for my 99 Mountaineer. I had already read some threads and watched some videos so I knew what I was getting into. So I took the actuator off some Gen 2 explorer I didn't even look at the year. But I had to drill out the rivet as some of you might now to remove the actuator from the door itself. That was easy and I got it out no problem.
So today when I went to install it. Popped of the door panel, peeled back the water screen, unbolted the window track, discontented the wires to the window track, disconnected the electric from the actuator and when I went to look to drill out the rivet it wasn't there. Instead it had one of those plastic pull tabs for panels. I popped it out and connected up the new actuator and make sure it worked then checked the plastic insert to see if it would go in the actuator i got from the junkyard and drilled out and sure enough it fit perfect inside of the plastic ring in the metal bracket.
I never sall anyone else have one of those plastic tabs to hold the actuator. Is this something ford switched to in the later models of explorers/mountaineers?
