Halwg
- February 5, 2012
- WV
- 2018 Explorer Base 2.3L E
This is my 5th Explorer, all of them being leased and used for my job as a consulting engineer to the oil and gas industry. As such, the Explorer is used to haul a lot of very expensive test equipment, and for what I call "light" off road travel.
I have to take the Ex to client's job locations such as compressor stations, well sites, and pipeline jobs. A lot of this travel is off of paved roads on gravel, or dirt access into the sites. Terrain is very steep and uneven in the areas I work, so 4WD is a must.
The previous 4 Explorers, though not perfect by any means, did a good job of handling the equipment and terrain. I drive about 25,000 miles per year, so in a 3-year lease I'll have nearly 75,000 miles.
So the big question is...will a car-based crossover SUV with some semblance of 4WD be able to stand up to the rigors of the job? Only time will tell. However, a few observations:
I've driven the vehicle for 4,000 miles and it has worked OK so far, but I haven't been in any situations that would call for hard-core 4WD. This winter will put it to more of a test, when I have to traverse roads and terrain in winter conditions. This was where the previous Explorers shined. I'm anxious to see if this one is up to the task.
- I can haul less in the 2014 than I could in previous Explorers even though the 2014 is larger
- The ride in the 2014 is significantly better than the previous Explorers.
- Better shifting transmission
- The Hill Descent feature actually works pretty well.
- It's impossible to find an off road tire in 245 60 R18
- The 3rd row seats are useless and I have them permanently folded and covered with a mat.
