Edward K
- July 8, 2012
- Madison, SC
- 1995 Explorer Eddie Bauer
Okay, I posted a thread a while back on a rough idling problem. Thought I had it fixed, but apparently the car thinks otherwise. I keep pulling codes every few times I do something to it and the codes have gone from a consistent 332 to a consistent 335. These codes will not quit, they keep coming back no matter what I do.
As far as the EGR system goes, I've replaced the PFE and the EGR both of which made the engine run waaay better. I've cleaned my MAF, and IAC both. All the vacuum lines seem fine, (went around them with a hose to my ear didn't hear anything abnormal.) Tested the EVR which gave me 33 Ohms of resistance, and I've checked the fuses.
I am truly and completely confused at this point. I got it so the EGR would respond (fixed the 332) but now it says my voltage is out of range.(335) Since the emission system effects idling so much I figure it still has to be a problem there somewhere. Any advice or ideas you guys could share would be appreciated.
Quick easy list:
Replaced:
EGR
PFE
Fuses
Cleaned:
MAF
IAC
Checked:
EVR (33 Ohms)
Quick easy list:
Replaced:
EGR
PFE
Fuses
Cleaned:
MAF
IAC
Checked:
EVR (33 Ohms)
