EGR Problem Again? | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
EGR Problem Again?
mgmgmg
Plymouth, MN
'94 LTD '10 LTD V8
ok Ill make this short...
Had a problem with my EGR System This Feb. had no check eng. light, rough idle etc.. etc.. Did a code scan with my scanner got a 336 replaced the DPFE sensor and while i was under the hood tested the EGR Valve and EVR Vacuum Regulator. Found that all 3 were bad?! So I replaced all 3 of them problem solved. 3 months later going 65 mph down the freeway check eng. light comes on? ok ill do a scan again 332 and a 335? wtf egr again?
Im lost the X runs great... what would cause this? bad wiring i looked for a vacuum leak found none... Maybe i got a bad part? Like i said it runs great?
Any ideas?
