RustyMacintosh
- August 5, 2018
- Monterey
- 94 XLT 4x4 Exploder
First, I am a new member. I own a 1994 XLT loaded 4x4 Explorer with lots and lots of miles. BUT is very nice condition. Just dropped a new trannie in it. New radiator last weekend, never could get the fan clutch to come loose but it is working.
Mornings, it misfires on #6 for a spell, maybe 2-3 minutes at idle, then it clears up to a smooth idle. IT IS not exchanging any fluids. IT uses no oil, no anti freeze, nor does the exhaust smell when cold of anti freeze.
It does not overheat. But like I said it has a ton of miles on it. 265K.
I can get from a salvage yard a 88k complete motor. But it is a NON EGR motor. Mine is EGR. Since we are reg'd in a county of California that does not smog each year, I am not worried about that aspect.
If I bought it, other than plugging the exhaust manifold, (unless the complete motor has a non egr exhaust manifold), will the ECM run the motor as usual?
No issues?
As for the misfire, someone did say it could be a weak EGR. You can feel it smooth out like something just changed in the motor when idling at 1000 rpm's. I thought for a while it was an injector, but this is too consistent.
Fire it up cold, it misfires, then smooths out within a couple of minutes as if a vacuum or sensor closes, or opens, but everything is new. TPS, the vacuum connection on the intake related to the EGR, MAF, and has a 190 thermostat.
No issues?
