2good2btru
- January 3, 2009
- Kennewick, WA
- 1998 XLT 4.0L SOHC V6
Recently, where I like (Kennewick, WA), it's been getting fairly cold (as of this writing it's 12:15 and it's 4 degrees outside) and it's only going to get colder. My 1998 Explorer starts fine in the morning, but I've been noticing a large hit in gas mileage and cabin heat over the past few weeks. I'm thinking of installing a Freeze Plug type Block Heater in it tomorrow.
I've been looking over this thread: http://www.explorerforum.com/forums/showthread.php?t=257152&page=1 It all seems to make sense to me, but I just wanted to check with you guys to make sure I understand what I'm doing before I go and mess something up.
1) Drain all the engine coolant.
2) Jack up the car and remove the front-right tire
3) Use a hammer/flathead and gently tap out freeze plug under the wheel well.
4) Clean debris from hole opening with cloth.
5) Insert Block Heater
6) Coat the O-Ring with RTV (not sure what this is?)
7) Turn the bolt to tighten in opening
8) Return wheel.
9) Refill engine coolant (actually, i plan on replacing it.)
Anyway, I'm just worried about my baby and wanted to know if I'm missing something? Or maybe am I missing the entire point? Any tips or pointers would be great, because I'm most likely going to need it.
Thanks, guys!
8) Return wheel.
Thanks, guys!
