albator
- January 14, 2020
- Bonny Doon, CA
- 1999 Mercury Mountaineer
I removed the oil pan without issue. 10mm bolts. The inside is super clean, it's surprising. And not a single drop of oil dropped!
The old gasket is really stuck, and there seems to be some extra adhesive, a white paste.
How to remove the old gasket?
When I install a new gasket, should I also add extra sealant?
What's your preferred sourcing of parts for the new gasket? Preferred brand?
I couldn't find the OEM Motorcraft part number?
What is the torque spec?
Should I re-torque the upper side too, like advised for the transmission?
