Engine Rattle On Start Up
BMan5150
O-HI-O
2014 Ford Explorer Sport
My 2014 Sport (73,000 Miles) has a rattle when you first start it after sitting for more than a few hours. It’s worse overnight and when cold. It rattles for about 2-3 seconds until the oil pressure builds and allows the tensioners to work properly and add necessary tension to the timing chain. No CEL/MILs and the truck runs great.
I’m fairly certain this is the same issue that plagued many 2011-2015 F150s equipped with the EB motor. The timing chain stretches and ultimately will trip a CEL for a misfire due to the ignition timing being off. I’m oversimplifying the scenario but that’s the gist. It’s apparently a $3-4K repair to replace the timing chain and tensioners.
So....has anyone else had to replace their timing chain tensioners and/or timing chain on their Sport?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
If a waterpump replacement is $1,500ish, I'm not sure why it would cost much more to do the chain/tensioner since it is all accessible when doing the pump.
Odrapnew
MN
2014 Explorer Sport
To expand on blwnsmoke's comment, bring it in say you want the water pump replaced and while they're at it, throw in new chain and tensioners.
It's all open anyway to get to the water pump, it can't cost another $1500-$2500 to do those as well. :)
BMan5150
O-HI-O
What I’d really like to know though is if other sport owners are experiencing the rattle noise for a few seconds on cold start ups and/or have had to replace their timing chain and/or tensioners. Perhaps it’s just a little stretch and the tensioners are just doing their job since the noise goes away after a few seconds. It’s not a sound I recall in any other car I’ve ever owned that had a motor with a timing chain. My mustang GT had almost 90k very hard miles when I got rid of it and didn’t make this noise.
I am going to have the dealer check it out sometime over the next few weeks. The other thought that crossed my mind was that the sound seemed to get louder after the last oil change. I always take it to the dealer for oil changes. I also checked the oil level-all good.
donalds
Location
Stem
Nc
1999 ford explorer sohc
This problem happens to a lot of 4.0 shoc engines it's louder softer oil change because the filter is not full and air in the system
mine did this
Rattle on start up
Louder after oil change
I instal a pre oiler fixed the problem
donalds
Location
Stem
Nc
Plus there are a ton of other benefits to installing a pre oiler spend some time reading on here
Took me a little reading here to understand all this mess
donalds
Location
Stem
Nc
What engine do you have
Here is a permanent fix for the 3.5 l ecoboost
BMan5150
O-HI-O
I’ve got the 3.5L V6 Ecoboost. Thx
BMan5150
O-HI-O
I’ve read all about that TSB but oddly it doesn’t apply to the 2013+ Ford Explorer Sport, the Ford Flex’s with the same motor or the Ford Taurus SHOs with the same motor.
donalds
Location
Stem
Nc
Ahhh ok hope you get it figured out
But the pre oiler will work for you in that respect
It's the best automotive investment I have made
Keep us updated
Tsuga
2013, Explorer, Sport
My 13 sport is rattling when starting cold in the morning. Took it to the dealer and they scheduled for it to come in on Tuesday for a tear down. They seem to think it is a bigger issue than the timing chain when I played them several videos clips that I took.
reserved50
2013 Sport Exploder
variable cam gears rattling, also needs chains, guides, tensioner, water pump etc. If its a loud clacking type noise for about 3 - 5 seconds
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
If it was the timing chain wouldn't it make noise every time you started the engine? If it runs/starts normally at all other times I wonder how serious it could be. Are oil and fluid levels where they should be? Any exhaust smoke?
Sixonemale
2015 XLT Appearance Pkg
Because you own a Sport the first thing that came to mind was the wastegate arm/valve associated with the turbo. Not sure if this is your problem, but below is a thread that sheds more light on this potential issue:
2.0 eco rattle
Tsuga
These are the sounds it made when the vehicle has been sitting for a while or over night.
Tsuga
Yes, just had the transmission fluid and oil changed in March. There is no smoke in the exhaust. It runs fine.
reserved50
2013 Sport Exploder
that's sounds horrible like theres no oil in it :confused:, maybe its just the way the microphone picked it up. Classic worn timing components sound like this
Tsuga
The oil is at level and I have 800 km left until the oil change is due.
323citopaz
Philadelphia
2016 Explorer Sport
2018 Explorer Sport - cold start - rattle noise. Did not go to dealer yet.
