uh60james
- February 19, 2006
- Fayetteville, NC
- '93 Sport (Dora), '06 XLT
Behind the cat's where the exhaust pipe and the muffler pipe meet there is a clamp of sorts holding the too pieces together. There are two bolts running through it and a the nuts appear to be welded onto the cat side. My problem is that the spring on the outside bolt has broken so that side of the pipe droops down some and exhaust leaks from there, it sounds terrible. The bolts are siezed up pretty good but I might be able to get them out or cut them and get a replacement. Does anyone know if the spring can be bought by itself? I assume the clamp is part of the cat pipe, too much $$$ to replace that. Any help, thanks.
