WizardOfOdds
- March 29, 2007
- 92 Explorer
Ok this is pretty much a general repair question, I hope I posted it in the right section of the forums... so the leak is at the 2nd Cat in the exhaust near the back... The Cat has like a metal shield circled around it. There is a hole in the Cat and the shield, I know this because when u run the engine, and then get out, you can see all the water on the ground and I looked up and saw a hole in the shield under the cat.
Now, this has me a bit worried for a couple reasons... Can I just use JB weld and close the hole? I also remember seeing inside a cat, its filled with a bunch of beads that filter the exhaust, if there is a hole in the cat, would all the beads have poored out making the Cat useless? I read up that some cars actually have drain holes in the exhaust to prevent lots of water from staying in the exhaust, I hope this is what the leak is, but I cant find any information about a drain hole in the exhaust for explorers.
Also, about the water... the exhaust shoots out a fair amount of water from the tail pipe and from the hole in the cat... What might be causing this water? I was thinking condensation, but it does it in any weather... any ideas? Any comments would be very appreciated, thanks!
