Sambosat
- November 21, 2020
- Khobar
- 2010, explorer 4l
Dear Valued members. My 2010 Explorer after I have cleaned the throttle body the car started to shut off randomly showing oil light. I turn the engine off and then restart the car, then it will work until next shutdown. I was thinking it is becuase of the throttle position and I need to reset it. So on Youtube, a mechanic was mentioning the following way to reset the throttle position
1- unplug the negative battery terminal
2- short it with the +ve terminal for few minutes.
3- reconnect and start the car
4- leave it running for about 15 min.
I'm not sure if this process is correct or not. If not can anyone explain the right process. The other question is, the symptoms that I have explained in the beginning are they caused by the cleaning of the throttle or there is another issue. Thank you for your help
