Explorer 5.0 awd transfer case swap. | Ford Explorer - Ford Ranger Forums - Serious Explorations
DUDER 1
Nomad
94 XLT
Hello so i have been getting everything ready to start my sas on my 5.0 explorer, and i dont wat to leave it awd. I was wondering if anyone has done a t-case swap. I have heard youcan use a t-case out of a f-150. Please ponit me in the right direction because i do not have a clue. Thank you.
DUDER 1
Nomad
94 XLT
Sweet ill check it out i dont think the awd would do so good with my sas. Thanks alot.
turboexplorer
Eagle Mountain, UT
98' XLT 5.0L 4X4
Callsign
Turbo
DUDER 1
Nomad
94 XLT
So i am a little confused about the spedo gear thing. What year do i need, do i need the spedo gear or not. Thank you i am confused
gavin
Anchorage, Alaska
'97 Explorer XLT AWD 5.0L
it depends on what year your Explorer is, something you haven't mentioned in the thread.
look at your t-case; does it have a VSS in it? I believe it was somewhere in the 1997 MY that they removed the VSS from the t-case.
If you have a 98+ it will not be in the t-case.
If it's a '97, it's iffy.
If it's a '96, it will be in the t-case.
DUDER 1
Nomad
94 XLT
Its a 1998. Im not sure of the month though. I am going to the local yard on my day off to look for one,
gavin
Anchorage, Alaska
if it's a '98, the month won't matter.
you can use a 4406 whether or not it has the sensor.
DUDER 1
Nomad
94 XLT
Ok thats good, the wiring thread for the 4x4 lights should be about the same no matter the year right. Just to make sure i can get a bw 4406 from 1997-2003 sensored or not and ill be good. Thank you.
