Explorer A-Pillar Rattle/Noise | Page 66 | Ford Explorer - Ford Ranger Forums - Serious Explorations
monroegal
Monroe, LA
2016 Explorer
Thank you for your reply. I read another post that suggested it was an issue with the "cowl" but thought the service guy would have been aware of that. I haven't heard back from anyone so I think I will call today and make this suggestion to see if this was checked. Thanks again for your input.
Napalm
Memphis tn
call ford motor and complain
our dealer gave us a loaner car no issue. granted we drove it with the noise for about 5 days while the parts came in.
OH and Temp fix - we tapped the cowl to the window with some painters tape and the noise stopped.
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 XL '16 XLT
Had this happen today myself. funny thing is when I heard it, I knew what it was from reading about it on the forum here.
I'll have try and recreate it however because it only happened once
Napalm
Memphis tn
our was easy to re-create.
drive over 64 mph - noise, go up to 75 - louder and higher pitched.
go past 80 on a test track in mexico - dims down and almost went way.
and like I said before - some painters tape taping down the cowl panel to the windscreen - prevented the noise for a little while.
musicforhim
Roanoke, Virginia
2016 Ford Explorer Ltd.
I'm having the same problem with a buzz or hum except it's coming from the drivers side, around maybe the A-post. Forgive my ignorance, what's the "cowl" ya'll are mentioning and where's it located?
BobbyMarks
Overland Park, KS
Ford Explorer XLT - 2012
[/URL][/IMG]
Napalm
Memphis tn
that bit of plastic and rubber under your wiper blades.
Flipee
2016 explorer
Wind noise
Just bought a 2016 explorer and when you are going 60 or more it has this annoying loud noise, can't figure out where it's coming from! Anyone having this prob?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wavey:
It could be the cowl. There have been several posts regarding a loose or improperly fitted cowl. That is the plastic piece that runs along the bottom of the windshield. Take it back and have the dealer check it out.
I merged your thread with this existing one.
sparky72
Dripping Springs, Texas
2016 Ford Explorer
I have the same issue. I took it back to be looked at, and picked it up today after they said it was fixed, but it is still making the noise. I don't think they replaced it because there were leaves on the cowl piece from my house, so why were they still there if they replaced the piece. I'm taking it back in
Flipee
2016 explorer
It's like a loud buzzing noise...they are replacing the cowl so we will see if that's the problem.
peterk9
Staff member
Moderator
Callsign
VE3
Please add the 'model' of your Ex to your profile so it always shows in the margin. Thanks.
Edwardlynch
South Florida
2016 Explorer Limited
I have a 2016 Limited. Drove it off the lot, got on the highway and heard the buzzing sound. I put a ton of things under the cowl where it touches the windshield and still it was buzzing. So, I simply folded the rubber part of the cowl, where it touches the windshield under itself and no more buzzing at speed. I don't see this as a permanent fix but at least it stopped the buzzing until I can get to the dealer.
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum. :wavey:
It seems that sometimes certain model years have their own unique issues. With the 2016 is back to noisy cowls. With the 2013 models it was a noisy fan for the internal temp feature.
Edwardlynch
South Florida
Thanks. This is a great forum and it has been quite informative. Since the 2016 is new, I am sure that there will be issues. I still love the vehicle. I hope to see more 2016 guys talking about them.
bhorak
So California
2016 Explorer Sport
I have the same problem at the same speeds mentioned in earlier posts, but couldn't recreate it when I took it to the dealer today, go figure. It seems to be not just the speed, but needs a wind component to cause the issue. They said they cant just order it based on my reporting the issue, so we shall see.
At least (from my 2012) they fixed the legroom for the driver, the radio antenna and the console coin tray clips breaking off. Hope they fixed the coat hook breaking issue as well. Now if they only had brought back a real retractable cargo cover..........
FordService
Official Ford Rep
Dearborn, MI
I have the same problem at the same speeds mentioned in earlier posts, but couldn't recreate it when I took it to the dealer today, go figure. It seems to be not just the speed, but needs a wind component to cause the issue. They said they cant just order it based on my reporting the issue, so we shall see...
Welcome to the forum, bhorak! When you were at the dealer, did you take the tech on a test drive? You may have a better chance of recreating it when you're on the road. What's the current mileage on your Explorer?
Crystal
hansenfarm
Illinois
hansenfarm
Also have a 2016 Explorer Limited and it has several thousand miles on it. We get the high pitched buzz with no regularity.
The first time it happened we were facing about a 30 mph wind at 45-60 mph and it was loud enough to be very annoying. The second time it happened there was very little wind and we were not facing it but again going 45-50 mph. Has not happened for a week or more.
Wondered about using tape when it starts doing it to see if it stops. If that stops it, could cowling be sealed to windshield or is there a reason it should just lay against the windshield?
Would appreciate any thoughts anyone has.
Local service dept. tried to be helpful but no way to catch it acting up.
peterk9
Staff member
Moderator
Callsign
VE3
Chances are, given the number of similar issues, it is the cowl and it should be checked by the dealership. You can try taping it down and if the noise is gone then you've isolated it. It may be loose so that it can be removed to clean outr any debris that accumulates there. Just a guess.
FordService
Official Ford Rep
Dearborn, MI
I have the same issue. I took it back to be looked at, and picked it up today after they said it was fixed, but it is still making the noise...
Hey guys,
Did the dealer resolve your concern? If not, please PM your full name, VIN, mileage, dealer, and best daytime phone number. I’ll loop in a customer service manager for your region to assist! :)
The first time it happened we were facing about a 30 mph wind at 45-60 mph and it was loud enough to be very annoying...
Hello hansenfarm,
Have you considered seeking a second opinion from another Ford Dealer? In the meantime, please PM the information I requested from sparky72 and Flipee. I’ll get this escalated! :D
Tricia
